need carb help
Old Aug 7, 2006 | 02:16 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
need carb help
wen i first got my 86 camaro, wen i started my car the idle was very high. but once it warmed up it slowly went down to normal.then as the days went on wen i first started it, it idled really high.then it started to get stuck.i would have to slam the gas for it to get unstuck.then i found out it was my choke thermostat spring. i had to tighten it,once i tighted it it idled perfect. but now it dont warm up fast.it takes like 10min. for example, wen i first start it wen i slam it it bogs but wen i slowly step on the gas its ok(wen its cold).once its warm it stops. so i was wonderin should i hook up my fan up to a switch so wen i start my car it would warm up faster n then after a couplle minutes i would turn the fan on??? please help thank you
Old Aug 7, 2006 | 04:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You either aren't getting 12 volts to the choke thermostat, or the thermostat is shot. By moving it, you didn't fix the problem, you crutched it.
Make sure you've got 12 volts there with the switch on and the connector unplugged from the thermostat, and if you do, replace the choke thermostat.
Old Aug 7, 2006 | 05:06 PM
Car: 86' Z28 Camaro
so do i have to replace just the spring or the whole housing if the thermostat??
Old Aug 7, 2006 | 06:39 PM
five7kid's Avatar
The spring is attached to a plastic plate. Those two come as a unit that are removed and replaced in the metal housing bolted onto the carb body.
Old Aug 7, 2006 | 07:39 PM
Car: 86' Z28 Camaro
how do i kno wen it is on right? like how tight does it have to be? or does it go right on?
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i have almost the same prob but when my car is warmed up and i turn it off and go into a store and when i go back in the car and start it it doesnt stay runing it just dies so i have 2 hold the throttle 2 about 1.5 grand then the choke will kick it wuts wrong?
Old Aug 7, 2006 | 10:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I remember responding to a schwack of posts back in the day about setting the choke up on a q-jet, but I could only find one post:
https://www.thirdgen.org/forums/carb...ighlight=choke
This should 'enlighten' you as to how a choke works on a q-jet. Try that stuff.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
