Mallory 4309 and vacuum/boost port?
Old Aug 20, 2006 | 03:23 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
Most of the pictures I've found on here have the vacuum/boost port disconnected. Is it not worth hooking up?
Old Aug 20, 2006 | 03:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
boost port will raise boost for supercharged situations, otherwise just set at 4-7psi and call it a day.
Old Aug 20, 2006 | 03:34 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
If it was hooked to a manifold vacuum source wouldn't it lower fuel pressure at an idle and let more fuel return to tank. This could make your fuel pump live longer and run cooler.
Old Aug 20, 2006 | 07:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I was having problems with my fuel pressure remaining steady when I had it connected, sometimes the pressure would be 2psi, next start it would be 10psi - so I disconnected it on mine and no more problem.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
