no gasket
Old Aug 21, 2006 | 01:03 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
no gasket
Hey there, my 84 camaro has had the intake replaced before I bought it.
I was taking the carb off the other day and also found a plastic spacer between the carb and the manifold. To my suprise, there was NO gasket at all on either side of this plastic spacer. Since the q-jet is a vacumm dependant device, shouldn't there be gaskets here to prevent vac leaks??.
Maybe something with this spacer(plastic bout .25 thick) doesn't need a gasket??
Should I put some in when I put it back together?? I don't think it would hurt anything, but I've been wrong before.
Old Aug 21, 2006 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It sounds like you are describing the typical q-jet insulating gasket. Although, every one I've seen was a 1/4" thick pressed paper (gasket material) with plastic bushings in the bolt holes.
If you could post a pic of this spacer you have, it may help us determine if that's what you've got.
Old Aug 21, 2006 | 01:47 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
or maybe it really is an aftermerket phenoly spacer,
hard ot say without being able to see it
is it really plastic ? for sure ? definitely ?
the stock replacement insulating gasket are usually black, and are about 1/4" thick yes
also has round plastic grommet insert holes in it where the four mounting bolts to go through it
Old Aug 23, 2006 | 01:21 PM
pizza_guy's Avatar
sorry, no way to take a pic.
Very sure it is a polymer of some sort(plastic)
Yes it's very black, and very flat.
I will look for those inserts next time I'm home. My memory tells me they aren't there, but i'm not 100%.
If I were to place gaskets here anyway, do you think it would harm anything?
If it would help, the manifold has "edelbrock" cast on it. It is a dual plane design.
If they came stock in some applications(mine is 84 L69 camaro), I would bet it probably is a stock unit. I bought this car 99% stock except the intake manifold. The only unknown.
I appreciate your replies.
Old Aug 23, 2006 | 02:04 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
i dont think putting gaskets in just in case would hurt anything.
Old Aug 23, 2006 | 05:44 PM
pizza_guy's Avatar
okay, gaskets it is.
Old Aug 23, 2006 | 10:54 PM
AcedRaven's Avatar
Car: 1987 Firebird Formula
Sounds like a carb spacer to me.. Also they sell adapters for qjets on those eldebrock manifolds if the person you bought the car from didnt by the manifold for a qjet, they may of just bought the adapter and put it on. Using gaskets shouldnt hurt anything, so id say try and see.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
