vacuum advance 3 part ?
Old Sep 13, 2006 | 03:48 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
what does the vacuum advance do? and how important is it? i tried to blow air through mine but its plugged and the hose coming off of it is plugged into the intake, is that were it should be plugged into or should it be off the carb?
Old Sep 13, 2006 | 04:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What motor? Your stock 305 in that car shouldn't have vac advance on the dist, but assuming it's been replaced...
It gives better efficiency on the highway. So more MPG, better combustion (less plug fouling) etc.
Pretty important, unless it's a race car, it should have it.
It should be plugged into a "ported" port on the carb, then to the vac advance can.
The vac advance can isn't something you can suck on and see if it works.... Well unless you're the type who can "suck the chrome off a bumper" it's a waste of time.
If you're plugged into the intake manifold instead of the carb, you'll have lots of ignition timing at idle. This may be a good thing, most of the times, not.
86IROC112
Aug 17, 2015 02:00 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
1nastygta
Aug 8, 2015 07:38 PM
