Off idle carb tuning
Subscribe
Oct 14, 2006 | 04:36 PM
just converted my tbi to carb i used i holley street avenger 670 cfm, i have the choke set, the idle mixture screw set, and the primary float level set. the problem i am having is if i rev the engine in park around 1200-1500 and up it will go super lean, my wideband tuner is reading an afr of 19 sometimes. what do i need to adjust to fix this, it has a horrible off idle stumble in drive as well, then it catches itself and drives fine?
Reply 0
Oct 14, 2006 | 06:12 PM
what's your vacuum at cruise and what power valve are you running? now for off idle are you talking pulling up to a stop sign then barely giving it gas and it'll stumble for 2-3 seconds then catch itself?
Reply 0
Oct 14, 2006 | 06:53 PM
not sure what my vacuum was a cruise i know it idles at about 60-65kpa, im running the stock power valve that came with the carb, and yes it i come to a stop at a stop sign and then go it will stumble and almost die, then i let off the gas and it will catch itself. every time it stumbles it goes lean.
and it said it comes with a fourth gen power valve
Reply 0
Oct 14, 2006 | 07:02 PM
accelerator pump?
Reply 0
Oct 14, 2006 | 10:39 PM
Definatly sounds like it does not have enough acceleration enrichment.
Reply 0
Subscribe
