Wanting to build a CCC Carb setup
Old Oct 13, 2006 | 10:31 AM
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
Hello all! I have a 84 LG4 system on a 350, with headers, performer intake, and 1.6 rockers. But my harness is all cut up, and the thing really doesnt run that good. I still have the problem of the high-rpm breaking up. What i want, is a new harness, and better ECM. Did GM use any different ECM's with teh different carb setups? Or should i just swap to Non-CC. I like the CCC Setup, good fuel economy. So what should i do?
Old Oct 13, 2006 | 12:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've heard the '85-'87 were different than the earlier ones, and a little better. But, I couldn't back that up with any real data.
If you have decent junkyards in your area, you may be able to find one of the later ones that hasn't been hacked up and pull everything out of it. I think I'd try that, and it should be cheaper than converting to non-CC.
Old Oct 13, 2006 | 05:45 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I don't know your preferences but unless you have to pass an emissions test or you're just a die-hearted fan of that "jewel" (sarcasm) called the cc-qjet, scrap it...gas is going down by the day so soon there will be no real advantage of the cc-qjet setup but to each his own and good luck whichever way you choose to go.
Old Oct 13, 2006 | 06:49 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
junk the cc carb as well as the distributor and get a comp 9000...had one for 10 years and haven't even had to change the cap or button let alone the module...as for the carb....you can get rebuilts all day for 100 bucks...
Old Oct 13, 2006 | 07:41 PM
five7kid's Avatar
More than likely, the best option for getting it running properly and for the least amount of money, is to fix what you've got. As you have already assumed, it certainly is the better choice from the standpoint of long term operating costs. Gas isn't going to stay this cheap forever - next year this time I'm sure we'll be looking back longingly to today's "good old days of cheap gas". I can certainly remember being shocked at having to pay $2/gal - it wasn't that long ago, and better economy saves money whether gas is $1.75/gal or $3.50/gal.
Old Oct 13, 2006 | 09:55 PM
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
Alrite. Ill try to fix what ive got. Do i need to throw new secondaries in the CCC, b/c at wide open throttle, it pops through the carb. would that be a lean condition, or an igniton problem? it sucks, because in second gear, i have to let off the gas to let it shift. i think i may have a fuel starvation problem. Last time i checked, timing was advanced 6*.
Old Oct 14, 2006 | 11:46 PM
five7kid's Avatar
If you aren't maintaining fuel supply to the carb, then nothing else you do is going to help.
If ignition isn't up to snuff, then nothing you do to the carb is going to help (6 degrees base timing is probably okay).
Old Oct 15, 2006 | 12:43 AM
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
would a stock 305 fuel pump be enogh to feed it at high rpms? and recently, ive been getting that thing, where the tach jump around , and the motor acts like its going to die. Any ideas? I really appreciate the help!
Old Oct 15, 2006 | 10:52 PM
five7kid's Avatar
A stock pump will be fine.
If you tach is jumping around and the engine almost dies, that's indicative of a failing ignition system, most likely the ignition module and/or coil.
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
pimp2303
Jul 27, 2017 02:03 PM
86camaroman201
Aug 19, 2015 04:52 PM
Street Lethal
Aug 13, 2015 08:28 PM
