Still have a hesitation..
Here is the setup:
350 rpm air gap, 670 street avenger carb VS
vortec heads, lt-4 hot cam
fuel pres at 6psi.
I have played around with the timing so far best at 15degrees initial.
I changed the accelerator pump cam to blue in the No. 2 hole, still had a hesitation, so I changed from a 31 shooter to a 35. I still have a hesitation.... any ideas?
fuel pres at 6psi.
