Keeping factory instrument cluster
Old Oct 26, 2006 | 10:23 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Right now i have a 91 305tbi Rs i am looking to switch to a carb in preperation for a 350 of some design still to be determined.... and i am looking to keep the original instrument cluster and run it through the ecm... is it possible could i just put in a new coil and distr. and just disconnect the old ones...?
Old Oct 26, 2006 | 11:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The instruments aren't run through the ECM. So, with a distributor with vacuum and mechanical advance, you're good to go.
Old Oct 27, 2006 | 04:06 PM
Car: 91 RS
Engine: 350 vortec
thanks a bunch!!!
Old Nov 2, 2006 | 05:26 PM
superchevy72's Avatar
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
what about the speedometer? isnt 90-92 electronic controlled through the computer? If you took the ECM out, wouldnt the speedo stop working?
Old Nov 2, 2006 | 05:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Nope - speedo will be fine as well. Might have to change speedo gears if you end up with a different geared rear differential, but the speedo will work.
Jeremys87
Jul 14, 2022 09:08 PM
82tabird
Dec 21, 2015 10:22 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
355sbcTPI
Aug 19, 2015 04:38 PM
fonzie85
Aug 13, 2015 11:50 AM
