Carb TPS setting? and would a miss adjusted tps make the car backfire though the ehau
Old Nov 5, 2006 | 08:20 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
What should the volts be I see tpi tbi setting but not for the carb? also would hte tps make th ecar backfire though the exhaust? when the car was running I had about .85 on the scan tool.I knpw the car is not suppose to be running when checking this.
Old Nov 5, 2006 | 09:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
On my 84Z the TPS should read .48volts with the Ing on,Eng off & A/C solenoid(if equipped)disconnected.Some though are as low as .40 others as high as .55volts depends on the year/eng.When my old TPS went south.I tested it & it was reading from .90 to as high as 1.72 volts(original tps).I couldnt adjusted to the proper voltage.It would jump from .32 to .90+ volts.Then go up to 5volts at around 1800rpm.drop back to .90-1volt & gradually climp up to 5 volts again(WOT).At any rate,it never back fired at any RPM.
Old Nov 6, 2006 | 08:32 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
TPS should read from (around) 0.40 volts to (around) 4.0 volts at WOT. A bad TPS will, like BLACK Z said, give inconsistent and non-linear readings. A bad, or misadjusted, TPS should not normally cause back fire, but it will cause temporary rich and/or lean conditions that can contribute to back fire.
Old Nov 9, 2006 | 09:16 PM
BLACK Z's Avatar
Car: 86 Z28
carb tbi and tpi cars call for something diffrent?
so a carbed car is about .48 I think the tpi cars are .54?
Would a out of adjustment one cause a backfire thought the exhaust?
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86IROC112
Aug 17, 2015 02:00 PM
Exxon Limited
Aug 9, 2015 08:13 PM
