Code 15- coolant temperature sensor
Old Nov 14, 2006 | 06:10 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
I just wanted to give everyone a heads up in here since most of the code 15 threads that I searched were for TPI. I was getting a code 15. I didn't have a multimeter(really should get one) to test anything so I went ahead and ordered a new CTS from Dal at VanDeveer Olds(great guy). I wanted to get the pigtail connector as well since mine had a small crack in it but was told that was discontinued. After I installed the new CTS and cleared all the codes from the ecm it started throwing code 15 again so it was the electrical connector. I found that NAPA has this part under TSC200 for $10. So if anyone gets this code and your connector or wireing looks sketchy like mine did a trip to NAPA might save you from buying a sensor you don't need.
Old Nov 14, 2006 | 07:06 PM
Damon's Avatar
Yeah, you can still buy all those weatherpack/ECM connectors aftermarket from a specialty electrical connector supplier. Most good auto shops have such a catalog and can order them for you. Most often I buy new connectors for the electrical choke hookup- they're almost always mangled on QJet cars.
Old Nov 16, 2006 | 04:40 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
85t/alover turned me onto the fact that O'Reilly's sells the CTS with the pigtail for $13. It's a Borg-Warner part. A little pricier than the connector alone you got from NAPA, but if you need a CTS...
Searching their catalog the other day, it looks like they carry a few of the pigtail connectors for different sensors.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
89 formula TPI
Oct 6, 2015 08:40 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
