Carb dip
Old Nov 20, 2006 | 09:27 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Carb dip
Is there anything better than the Berrymans Chem Dip? Is there anything cheaper that still works good? I am going to need a large amount, and at $20 dollars a gallon that get expensive. THANKS
Old Nov 21, 2006 | 11:43 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Gunk Carb & Parts Cleaner, $20/96 oz.
Old Nov 21, 2006 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I didn't like how well Gunk worked for me. I think it was weak.
I'd go for the berrymans!
are you putting it in a parts cleaner, where you you need LOTS?
Old Nov 22, 2006 | 01:25 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
I'm not using it in a parts washer. I have about 50 Holleys, 10 Edelbrocks, and 2 Predators to rebuild so I will need a lot.
Old Nov 24, 2006 | 08:11 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I don't know about anyone else but the Berryman carb cleaner is CRAP! First off you really can't put any part in there because the opening in the can is too small. You can't soak a main body or baseplate. The parts that you do get in don't come out clean. Basically all this does is "loosen" the crud but doesn't remove it. I still have to take a toothbrush and SCRUB the gunk off and even then it isn't clean. I have rebuilt about 5 holleys and it is crap. I too am looking for something decent.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
efiguy
Sep 27, 2015 01:30 PM
