wtf mallory
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
wtf mallory
i got my 3 port 4309 malloyr regulator today and it has 4 ports and one return port at the bottom i only have a feed line and a return then the outlet that goes to the carb what do i about the other two is this the right part or am i missing something?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
3/8" npt pipe plugs work fine. You don't technically have 4 ports since one port is the inlet, which leaves 3 ports open. The return is the bottom one. On my car 2 ports go to the double pumper carb and one is for the solenoids.
Transmission: 4L80E/4L80E
They have multiple outlet (regulated) ports for either multiple carbs or multiple carb fuel inlets, plus enough for one to go to a fuel pressure gage.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
thanks alot guys tommarow im getting enough cash to get the rest of the parts i need to do the swap. Alls i need now is a carb.
2012sergen11
Oct 13, 2015 07:38 PM
gta892000
Sep 16, 2015 12:37 AM
