when chock is closed
Old Jan 12, 2007 | 03:47 PM
0uTcast13's Avatar
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
the car idles really high like 3 grand from sum reson. then went i hold it open and start it it idls fine. could a spring broken or the idle screw is to lose or to tight i really need to know or should i just get a stock carb of another camaro.
Old Jan 12, 2007 | 04:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The car should be on a fast idle while the choke is closed. See if you can find directions for setting the fast idle speed.
Old Jan 12, 2007 | 04:15 PM
0uTcast13's Avatar
Engine: 5.0 h.o.
i let it idle for like that trying to turn it down but it wont. is was fine a couple days ago could the carb be going bad?
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
