Edelbrock 600 Linkage Problem??
Car: 86 Corvette
Transmission: 700
Axle/Gears: 3:73 Z51
Howdy When I pull the trottle linkage all the way back are the secondaries supposed to open wide?? Mine dont.. does any one have a good picture what the linkage is supposed to look like..I bought the carb used maybe I,m missing somethig
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
it isnt suppose to open in park when you rev it have you drove it at all if so they should open when you drive it.
Car: 87 T/A
Engine: none right now
Transmission: prob th350
if you just crack the throttle wide open in your drive way the front two barrels are the only ones that should open the secondaries will only open under a load such as driving down the road so the only way to test it is to be driving and if they dont open when you driving your car will quit pulling at around 2000 to 2500 rpm
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The secondary throttle blades on an Edelbrock carb are mechanically actuated. They will open when the throttle is blipped past about 2/3 open. The secondary air valve above them may not.
Car: 87 T/A
Well if hes looking down he wont see the blades open the air valve will still be closed i just totally forgot about them being mecanical havent been around one for a while
theshackle
Sep 17, 2020 08:26 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
