how can i kill the cold start problem?
Old Mar 4, 2007 | 04:15 AM
blackdemon89ta's Avatar
everytime the car is cold it never wants to turn over unless i pump a **** load then after like 5 tries it will kick over.i have an electric choke i think it's set right not sure. carb is new to me. also how much psi of fuel should i be at? i have it at 7 psi.
Old Mar 5, 2007 | 07:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
First off, what kind of carb? Qjet, CC Qjet, Holley...?
Check the choke first. With the engine ice cold - like sitting overnight - open the hood and take off the air cleaner. Pull the throttle lever open and the choke plate should snap shut. At most, you should have about 1/8" gap open. If thats ok, start the engine - have someone else start it while you watch the choke plate. It should be open about 1/8-1/4" with the engine running, as the air flow into the running engine will pull it open a little bit. If when cranking it over and trying to start the plate stays completely closed, then the choke is adjusted too tight and should be leaned out a bit so it will let some air in. Once it starts, it should fast-idle around 1400-1700 rpm. If its lower, it should be adjusted up.
Old Mar 5, 2007 | 08:42 PM
its 1406 edelbrock. thanks that helped it was too lean so i riched it up. now it kicks over with just a pump of gas. thanks.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
