NEED HELP QUICK
Old Mar 7, 2007 | 07:55 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
NEED HELP QUICK
i need to replace my carb on my 84 z28 quick.
is my car electric choke?..i think it is but i need to know for sure
is 600 cfm sufficient?....i think it is but i need to double check
will an edelbrock carb mount to my edelbrock intake manifold, my stock quadrajet fits on it, and i didnt know if i would need an adapter?
is vacuum secondaries what i want?...i think it is, because mechanical secondaries are for hi performance applications...
http://www.jegs.com/webapp/wcs/store...43643_-1_10271
this link is where im going to buy from, so it would be extremely appreciated if you picked the one that will work best for my car.
thanks in advance...
Old Mar 7, 2007 | 08:23 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Yes, the 1406 carb will work for you, and bolt right up. You can use your stock q-jet mounting hardware for your cables on the edelbrock carb. You might want to order the jet and tuning kit for it as well if you have the $30 or so. it will help you adjust it better to your application, although it will run well out of the box. BTW, if its an edelbrock carb'd intake for four barrels, its a good bet their carb will fit
Old Mar 7, 2007 | 08:41 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
where is the 1406 carb...all i see is 1405 and 1407....?
if it is the 1405 you are talking about, will the manual choke work?
Old Mar 7, 2007 | 08:54 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
all the 1400 series edelbrocks ive ever had/come across always needed an adapter plate to bolt to the spreadbore intakes
do you still have the ECM controlled HEI and E4ME carb on yours ? if so then youll need to find a non ECM HEI too in order for it to run
you will need to decide if you want to install a manual choke cable in your dash and through your firewall or if youd rather run an electric choke like the factory carb was
also you would want a vacuum secondary carb, such as the Q jets are
they run smoother, better for everyday driving
whats wrong weith the carb you have now ? is it an E4ME or ?
good luck
Old Mar 7, 2007 | 09:14 PM
Car: '84 Berlinetta
Engine: ZZ4
The PN for the carb: (600 CFM elec. choke)
350-9900
And for the adaptor plate:
350-2732
And for the distributor: (vacuum advance HEI)
555-40005
Last but not least, the tuning kit:
350-1487
That is the set up that will work with the least amount of work. You can get all these parts through Summit as well, for a little less $$. Hope this helps.
Old Mar 7, 2007 | 09:35 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
thanks soo much berlinetta, you are a lifesaver...i love thirdgen.org, and with this kind of help i will be around for a while...
Old Mar 7, 2007 | 09:49 PM
Car: '84 Berlinetta
Engine: ZZ4
Hey, as for summit, just change the first three digits (350) to EDL, and for the distributor, use PN SUM-850001R, its the same thing, just $25 cheaper. Oh, and summit and jegs will price match each other all day, so just get the lowest price for each part and call which ever you like, they will cut you a good deal.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
