Edelbrock linkage
Old Mar 12, 2007 | 05:40 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Edelbrock linkage
Is it possible to hook up the trans kickdown cable to an Edelbrock 1405?
Also, where can i find or make a stud that goes through the air cleaner to hold it down?
Old Mar 12, 2007 | 09:46 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Parts
for the carb stud and the kickdown bracket go to your local parts store as
99% of them stock what you are looking for.......
Old Mar 12, 2007 | 11:35 PM
77monte's Avatar
Car: 77 Monte Carlo, 89 Firebird Formula
Engine: 355's
Transmission: TH350's
Axle/Gears: 10 bolt 8.5 3.73, 9 bolt 3.27
If you are hooking it up to a 700r4 you will want to do a search on a geometry correction bracket.. the edelbrock carb doesn't have the proper geometry to ensure the line pressure is correct for the varying throttle position
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
