How big is my Edelbrock
Old Mar 15, 2007 | 10:27 PM
MAC25DM's Avatar
Car: 1988 Firebird
Engine: 2.8 liters of fury.
Axle/Gears: Stock
Is there any way to tell how big my carb is? It was on the car when I got it. The only numbers that I can see on it are 8667. My car keeps running rich, bad and I have to take it through emissions.
Old Mar 15, 2007 | 10:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are there any numbers stamped on the front of the carb just above the manifold on the passenger side? Something like 1406, or 1411?
Old Mar 15, 2007 | 10:33 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Good call, there is 1405 and 1330. I didn't even see those. I had to look hard to see them.
Old Mar 15, 2007 | 10:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 1405 is a 600 CFM carb. Out of the box it comes with a manual choke, and a slightly richer "performance" tune.
Old Mar 15, 2007 | 10:37 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
1405 is a manual choke 500cfm carb with 'performance' calibration.
That is why its running fat on you. Pick up a calibration kit and lean it out
Old Mar 15, 2007 | 10:41 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Can I pick up a calibration kit at Autozone, or do I need to order it online? This is why I don't deal with carbs to much. Fuel injection is easier to me.
Old Mar 15, 2007 | 10:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You might be able to find it in a local shop. Probably best to try a more performance-oriented store for the best chance of finding one. Failing that, you can order one online from Summit or whoever. Check Edelbrock's website for the online manual for your carb.
Is your choke cable connected, and do you have the correct non-computer distributor?
Old Mar 15, 2007 | 10:48 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
No, my choke isn't connected right now. To warm for it, and it wasn't connected when I got it. I have an MSD distributor, so I don't know if it's computer controlled. I assum it's not since there are no wires or plugs going to it.
Old Mar 15, 2007 | 10:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The choke is open though? Does your distributor have a cone-shaped metal vacuum advance can on the side of it below the cap? Just checking some of the easy things.
Old Mar 15, 2007 | 11:30 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Yeah, the choke is open. No, there is no vacuum advance on the distributor.
Old Mar 16, 2007 | 11:14 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Well, I ordered my new jets and metering rods for my carb today. They are supposed to be here tomorrow at 10.a.m. The whole set for my carb was 54.00. I just ordered the smallest jet and metering rod for my carb which was an .089. According to the Edelbrock website, the stock is .100, so I should see a decent change. The guys at Checkers are beginning to know me. They said that if they were to small to bring them back for a bigger size, but I think it will be all right. Right now, it runs REAL rich.
Old Mar 16, 2007 | 11:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well, you might end up going way lean that way. If you were going to lean it right out though, you'd want the smallest jet and the largest rod.
No signs of flooding from your carb? No fuel dripping from the boosters, or anything like that?
Old Mar 16, 2007 | 11:42 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Not really flooding, just bogs when I get on it then goes. It's not dripping, out of anywhere, but you can see it fume out of the exhaust and smell it real good. I am pretty sure I am killing all the bugs around my floodlights. So I guess there is one advantage.
Old Mar 17, 2007 | 02:26 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Bump
Old Mar 17, 2007 | 03:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
If you have a bog when you stomp the pedal it may also be the pump shot. Which is an easy fix by removing the little clip and moving the rod to another hole...
Old Mar 17, 2007 | 03:19 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
carb may just be out of adjustment also. grab a vacuum guage, hook it up to the port on the front drivers side of the carb, near the very bottom close to the intake. warm the car, set the idle where you'd want it. 2 screws on the front of the carb can really control how the car runs. they face forward and up. make small adjustments of these screws to obtain the highest vacuum reading on the vacuum guage. the idea is to have the screws turned IN as much as possable without loosing vacuum. might save you from removing the carb and changing things around, but maybe not.
Old Mar 17, 2007 | 06:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What you really should be doing is reading the Edelbrock manual, which spells out step-by-step how to tune all the functions of the carb.
Old Mar 17, 2007 | 07:30 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
I read the manual on tuning. I couldn't tune it to not blow fuel fog out of the exhaust which is why I turned to the jets. I have changed them out with the new metering rods and it runs like a top now. I have to re do the vacuum gauge again, but there is no more fog now. Everything worked perfectly and fit great. The manual was helpful as far as how to change them.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
