PCV necessary
Old Mar 18, 2007 | 05:32 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
PCV necessary
I got my camaro a few years ago and havent really done too much with it recently. I'm starting an engineering co-op this summer and im gonna have money to get the beast running strong again. One thing ive noticed is that a lot of people just run two breathers instead of a breather + pcv valve. I dont remember offhand but I think mine connects to one of the carb vacuum ports. Anybenifit of running it either way? My motor is a 350 with a cam (266duration) and worked over stock heads.
Old Mar 18, 2007 | 05:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Using a PCV valve helps keep blowby gasses from condensing in the oil and forming acids and deposits.
Old Mar 18, 2007 | 05:46 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yep and its very important for the life and health of the engine
need one pvc in one cover and a filtered return in the other
preferably, that way it will tend to circulate through the crankcase and lifter gallery
good luck
Old Mar 18, 2007 | 05:57 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yep, a PCV does nothing but good for the engine!
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
