heater bypass valve question
Old Mar 21, 2007 | 08:19 PM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
Transmission: 700r4 with transgo shift kit
Axle/Gears: ?? not sure yet just got the car
ok i know im in the wrong spot but i just converted my 305 tbi to carb and had a question about the swap... my old heater core bypass valve has 3 lines... one from the intake, one from the heater core and one going to the radiator... my question is do i have to run one of the lines to the intake and what would be the disadvantages of not doing so? i pretty much want to bypass it altogether to clear up my engine bay a little and want to know how to go about doing this without losing my heater... any suggestions would be greatly appreciated..
thanks
or should i find a fitting for my intake and keep it.. if so what is that plug go and where would i put it on a edelbrock performer 2701?
Old Mar 21, 2007 | 11:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The intake provides the hot water for the heater. You can just put a hose nipple in the intake coolant outlet and run the hose directly to the heater if you like. The return can either go to the radiator or the top of the water pump.
The purpose of the valve is to stop the flow of coolant to the heater core on max AC while still allowing coolant flow through the engine before the thermostat has opened. By eliminating the valve, you might not have quite as cold of AC when in the max position.
FWIW, factory carb cars didn't have the valve (although I'm not sure about '87 - it might have, it was a weird year).
Old Mar 22, 2007 | 06:41 AM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
Re: heater bypass valve question
alright! thanks alot five7kid... answered exactly what i needed to know.. i think for now im just going to bypass it and see how cool the ac gets... if its not to bad ill just leave it alone for now
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
