idle mixture
Old Mar 22, 2007 | 08:16 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
idle mixture
i was setting it and i was just wondering how much vacuum i should get with a l98 with a stock cam.
Old Mar 24, 2007 | 11:22 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: idle mixture
Probably around 20-22" at 800RPM idle in park, or thereabouts.
Old Mar 24, 2007 | 06:21 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Re: idle mixture
ok right now it stays at 15 and says late ignition timing on the gauge does late mean too much or not enough?
Old Mar 25, 2007 | 02:06 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: idle mixture
Late means too little timing.
I wouldn't just trust what your vacuum gauge says as far as advice, but it's a good start.
What's your timing at that point, and idle speed?
Old Mar 25, 2007 | 03:50 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Re: idle mixture
well back when i set the timing it was at like 1800 rpms so im sure the timing is wrong i bought a timing light today and tommarow when i go back to my work ill mess with the car.
Fronzizzle
Feb 9, 2017 09:31 AM
amcnellis
Sep 16, 2015 04:16 PM
Rally Smith
Sep 14, 2015 06:59 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
