Holley 4150 650CFM DP Won't stay running
Old Mar 23, 2007 | 03:24 PM
Hammertime540's Avatar
Car: 91 Camaro RS
Axle/Gears: 3.42's Locker
I can't keep my Holley 4150 650 running on my 1991 camaro RS 305. I am watching the fuel flow and I only see fuel when I give it some throttle. When I can get it to idle for a few secounds, I don't see any fuel. I have a holley bypass regulator hooked up P/N 12-803BP.
Old Mar 23, 2007 | 05:05 PM
Car: 91 Camaro RS
Re: Holley 4150 650CFM DP Won't stay running
Never mind its a fuel pump problem.
Old Mar 23, 2007 | 06:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
at idle you won't see fuel coming out the boosters, the fuel comes out the idle circuit.
Old Mar 24, 2007 | 12:16 PM
Car: 91 Camaro RS
Yeah I found the problem, had to wire the pump to stay on when the ignition is on. It was only running for about 2 seconds every time I turned the ignition on.
Frozer!!!
Jan 19, 2024 04:55 PM
apo_bailon15
Mar 28, 2016 05:20 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 19, 2015 10:02 PM
86IROC112
Aug 17, 2015 02:00 PM
