85 camero q-jet trouble code problem
Old Mar 26, 2007 | 04:02 PM
85 camero's Avatar
Car: 85 berlinetta
Engine: 305 lg4 q-jet
Axle/Gears: stock going 3.73 posi
Its a fresh rebuild with 20,000 miles.Check engine light flashes the car chugs somes but when light goes out it runs strong.no codes come across at all nothing.anyone know why this things running like **** im new to a carb sytem cause i have the tbi unit in my truck.
Old Mar 26, 2007 | 04:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
So, you've checked for trouble codes using the ALDL, and get nothing. How are you checking for codes?
You could have an ECM problem such as poor ground, or an internal shorting or power opening. Check grounds first.
Old Mar 27, 2007 | 02:37 AM
85 camero's Avatar
Car: 85 berlinetta
Re: 85 camero q-jet trouble code problem
thanks for repling i bought the actron code scanner from advanced auto.where are these grounds and how many are there.my first camero and its alot diffrent from my tbi 350
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
chazman
Aug 22, 2015 02:01 PM
