weird fuel pump problem after carb swap
Old Mar 29, 2007 | 08:16 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well it seems my fuel pump is dying or doesnt work right without the sensors plugged in because sometimes when i go to start it the pump runs (i can hear it) and the car fires with one turn of the key other times the pump wont run and if i pump the carb it starts. When it does start it will run 5 mins then die ill start it again and it runs fine and doesnt die again.
Old Mar 29, 2007 | 08:47 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: weird fuel pump problem after carb swap
oil pressure switch alot of the times is in the FP circuit
Old Mar 30, 2007 | 04:39 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
When I did the TPI swap, I just rigged the pump at the relay to always be on when the key is turned. I ran a wire from the green/white wire on the relay to a 12v ignition source. (I used the slot on the fuse box where the fuse for the injectors went...didn't need that anymore )
Try that out and see how it works. Oh, might be a good idea to get a fuel pressure gauge to monitor what the fuel system is doing. You can get a hold of a cheap gauge at a speed shop with a T block for about 35$ total. Some guys say they are inaccurate, but mine stays pegged at 6.5psi now.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Newguy91rs
Aug 7, 2015 09:51 PM
