1985 Quadrajet help
Old Apr 15, 2007 | 03:54 AM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
1985 Quadrajet help
i have a Quadrajet on my 1985 camaro berlinetta 5.0 and i had a cracked fraim when i got it i just got the fraim fixed a few month ago so it has not been drove befor that but was started ever week but no i am driveing it i cleaned the carb befor i took it out was a cleaner befor i took it out car starts easy on the frist try but if i put it down the car rpm will drop and it does not gain them back fast at aww like it will takes me about a mile to get from 30-50 cant even get it past 55 kind of makes a noes like it is boging down and if the car is not warmed up it will acked like it wants to die but when it is hot it just has no power when u push it past haft way down like i said the rpm drops and it wants to go slower than if u only pushed it haft way i checked the gas lines and none are kinked because i no quadrajet use alot of gas wehen u kick in the 4 B but its got aww the gas it could nead i do not no how old the carb is because it was on the car when i got it and this is really the first time i have drove it sents i got it a year ago but sarted it ever week and i have filled it u with high grade gas in the past to weeks and ran it out and filled it again so its not bad gas i would like to try to fix it because i dont want to by a new carb at this time so can some 1 help me ??????????????????
Old Apr 16, 2007 | 11:32 AM
johnsonm's Avatar
Car: 86 Firebird
Engine: LG4 feedback controlled 350
Transmission: used to be T5 now T56
Re: 1985 Quadrajet help
Not to be an a$$ but this post is pretty hard to understand. There are lots of knowlegable folks here who like to help, but they have to be able to understand your question.
Your car runs poorly? Did it begin running poorly suddenly, or did it run poorly before you got it?
Are all the wires in the engine compartment attached to something?
Do you have any "check engine" codes? What are they?
The first things most here will tell you to do, especially if you just got the car is give it a full tune up (plugs, wires, cap, rotor, fluids, check timing, replace any rotten or missing vacuum hoses). Cover the basics, then begin troubleshooting. Don't assume the carburetor is the problem.
Old Apr 16, 2007 | 12:23 PM
Engine: 305 tbi
looks good to me just don't post on it because i ain't doing it again cant i no i am hard to understander i live out lot of little words like "to was ,a ,i ,you" but thats ok peace
Old Apr 16, 2007 | 11:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I can't understand what you're asking, you didn't use any punctuation..?
The more (understandable) info you give, the more useful info you'll get back.
I'd love to help you out, and I know a thing or two about the Q-jet, but I can't make heads or tails out of what you said...?
Old Apr 17, 2007 | 12:50 AM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
ummmmmmm.
ok ill have a go, Is youre choke opening at all?
The large plate over the front of the carbie, is it down flat or open so you can see inside the top of the 2 front holes?
If it is closed or almost closed it will be killing ALL performance and fuel econamy.
Old Apr 17, 2007 | 08:55 AM
Engine: 305 tbi
ok. I was on the phone when i first made that. I have a 1985 camaro berlinetta 305 . i don't ever use QJ but this time i am. to keep stock. the car runs fine at haft pressed fine but go an more. The RPM will drop and it will not want to get speed like it should.??????????
Old Apr 17, 2007 | 09:18 AM
johnsonm's Avatar
Car: 86 Firebird
The car runs fine to half pressed (half throttle?) but go any more and the RPM's drop and the car doesn't want to pick up speed like it should?
Throttle position sensor?
Problem on the secondary side?
Do you have both the correct computer controlled carb and distributor installed?
Old Apr 17, 2007 | 10:15 AM
Engine: 305 tbi
ever thing is hooked up and i dont think the Throttle position sensor is bad. i have had those go bad and it is nothing like that. i am sure it is in the carb.
Old Apr 17, 2007 | 10:50 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Is it still doing it after you completed the above?
Don't assume the carburetor is the problem until you've identified the carburetor as the problem. I read that somewhere.
Old Apr 17, 2007 | 11:55 AM
Engine: 305 tbi
yes done full tune up replaced ever hose even vacuum ones aw so change tran. filter. still got the problem like i did be for. no power when u push the Throttle past haft . push it past haft RPM drop and junt does not go any faster .
Old Apr 17, 2007 | 12:31 PM
naf's Avatar
naf
Some easy to check possibilities:
Clogged fuel filter-replace this
Choke stuck closed-make sure it's sitting straight up when the engine is warm
Choke pull off bad-remove vac hose, push it in, finger over hose nipple, stays in?
Secondary Air Valves stuck-tap with your fingers, it should move freely
Timing off/no advance-verify advance with a timing light
Old Apr 17, 2007 | 03:06 PM
85 camero's Avatar
Car: 85 berlinetta
Engine: 305 lg4 q-jet
Axle/Gears: stock going 3.73 posi
check for a bent fuel line from the carb.these QJ use a lot of gas.pull the altenator and check line that runs by the water pump thats were mine was bent at.
Old Apr 17, 2007 | 03:20 PM
Engine: 305 tbi
i did have a bent line but i put a new line in when i first got it
Old Apr 17, 2007 | 05:12 PM
VenomX-87's Avatar
What carbie were you using before the Q-Jet?
What is youre timing set at?
Are all youre plug leads on the right plugs? (Not as hard as you think to mix up if you replaced all the leads at once).
Have you got an in-tank pump or block mounted pump?
Did the car have these problems when you got it?
Old Apr 17, 2007 | 05:33 PM
Engine: 305 tbi
i did not change the carb and the car was not running when i got it because of a cracked frame witch i fixed and i just used the timeing light on my car at it is timed at 10
Old Apr 17, 2007 | 06:07 PM
VenomX-87's Avatar
cracked frame?
Old Apr 17, 2007 | 06:51 PM
Engine: 305 tbi
yea i got it off of a guy for like really cheap because the part of the frame behind the powering steering gear box was cracked .in about 4 cracks around witch will make the gear box flexed on the frame and u will have little to no steering. i work at a body shop so i just took it there and welded it . also redid a brake line that was leaking. an i have been driveing it fine. aww but the carb problim. it is worth fixing because the inside is meant and it is loaded ever thing power even cruise, ttops it is the berlinetta with the digital dash and the pods witch not many of those are left or where made.
Old Apr 17, 2007 | 07:32 PM
VenomX-87's Avatar
other than what I have already asked i duno what it could be, I have never seen nor worked on a a CC Carbie (I had never seen a Q-Jet before i got my T.A).
Old Apr 17, 2007 | 08:55 PM
Engine: 305 tbi
think i will get a new carb. maybe some one had it apart or messed with the setting on it or it could just be old pretty sure a new carb. will fix it .
Old Apr 18, 2007 | 06:32 AM
naf's Avatar
naf
Don't count on a new carb fixing it. There could be several things external to the carb that could be causing your problem. Before spending ~$300 on another carb I'd recommend rebuilding the one you've got, adjusting everything properly and checking the operation of all of your sensors. Rebuild kits run ~$20. With some carb cleaner and a few tools you could get where a replacement carb would put you for under $50 (and maybe figure out the problem in the process). See a semi-recent thread started by Nate86 on rebuilding the q-jet.
Old Apr 18, 2007 | 09:50 AM
85 camero's Avatar
Car: 85 berlinetta
you said ur timing set at 10.my 85 berlinetta says that timing should be at 0.reset ur timing and see what happens.i thinck the timing way off and the motors running retarded.i got the same car and mine runs great at 0 if you want advance it between 2-4 unless she starts bopping and detonating.
Old Apr 18, 2007 | 10:25 AM
johnsonm's Avatar
Car: 86 Firebird
Make sure the flat 4 wire plug at the distributor is disconnected when checking the timing also.
Old Apr 18, 2007 | 11:32 AM
Engine: 305 tbi
yea i did check my timing right i made sure of it and i had a about the same problem with my 1978 olds delts 88 350 and i went out and bot a carb. i mean the different was like night and day ran like a dream after that so i think i will get a new 1 and about rebuilding 1 i dont think i could do that to many things to F up
Old Apr 22, 2007 | 06:21 PM
Engine: 305 tbi
good news i rebuilt my carb an the jets where just clogged so thaanx for the help ever 1
Lbibb
May 5, 2016 12:00 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Liveaction
Sep 17, 2015 06:29 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
