edelbrock carburetor question
Old Apr 21, 2007 | 07:45 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
I want to put a edelbrock carburetor on my stock 5.0 305 camaro berlinetta motor what type of edelbrock carburetor should i use? I want an electric choke. If any one has any helpful hints of installing i would like to hear them.
Old Apr 21, 2007 | 08:23 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: edelbrock carburetor question
stock motor? Probally a 600CFM.
Old Apr 21, 2007 | 08:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Any reason why you want to use an Edelbrock?
Old Apr 21, 2007 | 09:04 PM
Engine: 305 tbi
because i dont like the stock carb and it is bad any ways and i like those duel pump holleys but they are a little pricey and i put a edelbrock on my 79 camaro which it had a holley before and i thought it ran a lot better but i am a little worried about putting one on my 5.0 1985 because it has a lot more plugs that will have no where to go and i dont no how that will make it run if i do not have electrical plug in to it i am just used to working with older motors and create motors that dont have so many plugs
and i am unsure if the linkage will hook up?
Last edited by diablo666mew; Apr 21, 2007 at 09:07 PM. Reason: Automerged Doublepost
Old Apr 21, 2007 | 09:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The Edelbrock is a squarebore carb. It won't bolt to your factory spreadbore manifold, so you'd need to change the manifold, or use an adapter. You'll also need to replace the distributor with a mechanical advance one, since the ECM won't be able to control the timing on the stock computer-controlled distributor without the input from the sensors on the factory carb. If you have an automatic transmission, you'll also need to do some wiring to get the torque converter clutch to lock without computer control.
Replacing the factory Quadrajet with an Edelbrock is a downgrade in all respects.
Old Apr 21, 2007 | 10:16 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
a 600 cfm will work good... summit racing can hook u up
Old Apr 22, 2007 | 12:02 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
x2
The edelbrocks look nice and all, but a properly set up quadrajunk will easily out perform it and at the cost of next to nothing.
If your going to blow some money, do it right. Buy a half decent carb for it!
Old Apr 22, 2007 | 12:44 AM
Engine: 305 tbi
thanx you are aww helping alot
Old Apr 22, 2007 | 03:05 AM
Engine: 305 tbi
SOOOOOO what carburetor should i go with any brand name i do not want to spend any more the 400.$$
Old Apr 22, 2007 | 02:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try a rebuild kit for the Qjet first.
Old Apr 22, 2007 | 06:23 PM
Engine: 305 tbi
good news i rebuilt my carb an the jets where just clogged so thaanx for the help ever 1 i would not recommend some 1 doing it those carb are a little harder to rebuild then most
beastin91rs
Oct 9, 2015 07:38 AM
fasteddi
Sep 2, 2015 10:29 AM
beachrodder
Aug 25, 2015 08:05 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
