what carb to i have?
Old Apr 16, 2007 | 04:46 PM
lpcamaro_z28's Avatar
i just bought my first camaro and i need to find out what carb i have, because it has no choke. the butterfly part that lets the amount of air in and out is missing. its a holley carb. is there a number on it somewhere i can look up, and where can i get a new butterfly? thanks
Old Apr 16, 2007 | 05:15 PM
Re: what carb to i have?
Old Apr 16, 2007 | 07:37 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
I had the Holley that was identical to the pictured one. I removed the mech choke assembly but it has the tower casting still. Some 'race' versions came this way and could still have it added. Some other 'race' versions had the choke tower milled down. I have a holley catalog, so look for the number as pictured from sofakingdoms reply and get it to us. FYI, I replaced the Holley with a BG Demon. It is identical in style but was the version without the choke assembly. Still has the casting tower to add it if I wanted to. Choke assembly foe either is availible. Some pics and part # would help though.
Old Apr 16, 2007 | 11:20 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
There should be 2 number sequences somewhere areound the bores. Generally in an easy to see place.
Old Apr 17, 2007 | 02:33 PM
ok i found out what carb i have thanks for the help.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
