4 barrel tuning
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
4 barrel tuning
I thought I saw a post on here a while back about fine-tuning a 4 bbl using a vacuum gaue to get both bbls equalized........not 100% sure it was on this site, but I tend to think so........anybody remember seeing that, or can find it again ?????
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: 4 barrel tuning
All a vacuum gauge will do for you is tell you how much vacuum your motor is pulling at various rpms, and that is about it. If you are reading low vacuum, then you know that you have to play with timing, or fix a vacuum leak, or something of the like. The only way to truly tune a carb is to get a wideband air/fuel ratio monitor to see if you are rich or lean at a certain RPM. You can also get a good idea if your carb is too rich or too lean by reading spark plugs (clean or sooty) or just tuning until you feel that you are not pig rich, and still making good power.
Car: 1986 IROC
Engine: 355" TPI
Re: 4 barrel tuning
You can use a vacuum gauge to tune a carb. Turn both screws in till they bottom out and then back them out 1.5 turns. Then adjust the screws equally until you have the highest vacuum reading you can get.
Re: 4 barrel tuning
I thought he was speaking in terms of richening or leaning
Car: 1986 IROC
Engine: 355" TPI
Re: 4 barrel tuning
Any carb can be tuned like this by turning the mixture screws. When you have the correct timing and idle speed the vacuum will read its highest when the mixture is good.
