Bad Carb Choice?
Old Apr 24, 2007 | 12:53 PM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Bad Carb Choice?
i feel a little dumb now ya'll, I dont know very much about carbs, I just assumed that all i would have to do is buy a carb and slap it on, so i found a 650 cfm holley carb off ebay for like 60 bucks or so, but I didnt really pay that much attention to any of the info, cuz i didnt really know..
well my friend looked at it and said he doesnt know where the downshift cable would connect to it.. so im first worried that its a manual transmission carb, if there is sucha thing.. second after i bought it, i found that the numbers on it bring up info on old fords, so i think i bought a stock ford carb.
and lastly, if this is some ford carb, will it bolt up? will we be able to use it with my 700r4? will i be able to buy the proper brackets for the tv cable? im really confused and worried that i screwed myself over.
D8PE -9510-AEA
List: 8409
0869
Old Apr 24, 2007 | 04:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Bad Carb Choice?
That's a Ford service part. You'd have to do some work on it to make it friendly to your transmission. Probably not worth the trouble.
Old Apr 24, 2007 | 09:38 PM
hectre13's Avatar
Engine: HO 5.0
shoot.. thats what i was afraid of.
Old Apr 24, 2007 | 09:51 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
any other numbers on it? like 1850 or 80453? should be on the front of the choke tower.
Old Apr 25, 2007 | 01:16 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Even if you were to get a chevy one, youll have to get a tv correction bracket, or a slotted stud to bolt onto the linkage to get the tranny cable to line up right and snap on.
Also, Holley has a nifty little carb calculator on their website. You should check it out, it will tell you which carb is right for you.
http://holley.com/applications/Carbu...bSelection.asp
Old Apr 2, 2008 | 08:15 PM
PRUNTI's Avatar
hello hectre13
this is a holley ford carburator, fits to a 429 cid ford thunderbird.
i have the same one and i am trying to decide to have it rebuilt.
if you still have yours, can i buy it from you??
i have been told on forum that it is hard to find a rebuilder that you can trust
camaro71633
Sep 1, 2015 10:24 AM
Jae992
Aug 27, 2015 09:07 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
