Edelbrock Manual Choke
Car: 1987 Camaro
Engine: 355
I have an Edelbrock 600 with a manual choke. Has anybody ran the choke cable and want to brag about how they ran it? Anybody know about how long of a cable I need? or a better place to run it. I don't want to cut a hole in the dash of anything. I would like to make it hidden as possible.
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Car: 1987 Camaro
Engine: 355
Re: Edelbrock Manual Choke
To convert, i'd have to buy an electric choke and wire it up. Manual choke is also better on gas....if you know how to use it
Car: 91 Camaro RS
Engine: Small Block
Car: 1987 Camaro
Engine: 355
It's better on gas if you start driving before the car is warm, you can open the choke all the way up while the electric choke would stay partially closed until it was warm
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
600, adjustment, bracket, cable, choke, convert, converting, edelbrock, electric, install, installation, manual, manul, problems, working
Easier conversion than running a cable, and a wire is easier to hide
