What is this part?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
What is this part?
I need to know what the name of this is so I can order a new one. The part that I outlined in green broke off, and I can't attach my TV geometry corrector bracket now. I'm not sure if you can replace this without taking the carb apart, but If I can order it, I can chop it off and weld it onto the old one that is on the carb already. (I think you can weld this type of metal, right?)
Transmission: 4L80E/4L80E
The part in red is the throttle arm. It is part of the throttle shaft. I've never heard of ordering just the throttle shaft/arm, but I suppose it's possible.
Re: What is this part?
Hrm, yeah I tried searching for that on summit, along with a slew of other terms and they don't offer it. Only the secondary linkage arm. Oh well, looks like I have to get creative
Are you running a Holley or an Edelbrock?
You might want to get a hold of these guys http://www.carburetion.com/Carter4.htm http://www.carburetion.com/holley.asp . They seem to have a lot of odd-ball stuff.
It's a holley 750cfm. Ditched the edeljunk and am putting this on this afternoon. Thanks for the links, as always!
LT1Formula
20
Nov 14, 2015 12:02 AM
