will offset base fit up in cowl hood
Old Apr 30, 2007 | 03:37 AM
F-BOMB's Avatar
I just got my parts to switch from TPI to carb and I bought a jegs 14x3 offset air cleaner. Jegs said you need the offset to clear the HEI dist. I have a GoodMark steel 3' cowl induction hood. Does anyone know if the offset air cleaner will fit up in the hood cutout or will it hit the side because it is offset. Thanks for replies.
Old Apr 30, 2007 | 10:35 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: will offset base fit up in cowl hood
It should be fine, although with a cowl hood you could have just bought the flat base air cleaner and that would have fit fine as well. Don't need an offset with a flat base.
Old Apr 30, 2007 | 12:30 PM
F-BOMB's Avatar
Thanks for the reply, I guess I'll just have to try it when I get the carb switch done.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
