unplug wiring solves problem?
Old Apr 30, 2007 | 06:04 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
i was having a boging problem with my carb when i tryed to accelerate. So i figured i would take an hour or two to mess around with it and first thing i tryed was unpluging the wiring and sure enough i started it up punched it and the problem was gone. Can anyone explain this and is it safe to just keep wiring off and continue use of the car?
Old May 1, 2007 | 12:51 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: unplug wiring solves problem?
You have to let us know what carburetor and motor you have, as well as what wiring you are talking about. On some applications, wiring can either mean you unplugged the headlights, or you unplugged your TPS sensor. Please be more specific if you want a response to your problem.
Old May 1, 2007 | 12:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It doesn't mean you've solved any problems, just masked them with new ones.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
perZ
Aug 21, 2015 05:51 PM
