PCV hookup on a Holley 3310
Old May 9, 2007 | 01:19 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
Just want to check to make sure if it is ok to connect the PCV hose to the full manifold vacuum port on a 3310 carb? I can't see where else it would go.
Kevin
Old May 9, 2007 | 01:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: PCV hookup on a Holley 3310
If there's no PCV port on the carb, drill and tap the manifold, or a carb spacer.
Old May 9, 2007 | 07:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Use the big one on the back of the carb, under the fuel bowl. That one is for either power brakes or PCV.
Old May 9, 2007 | 07:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Note the either power brakes or PCV. Not a good idea to put them both on the same port.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
NZKnight
Oct 15, 2015 02:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
