Car Bogs, No Power At WOT In 3rd Gear (700r4)
Old May 10, 2007 | 10:44 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i went to race my brothers mustang tonight, we stopped, i brought my rpm's up to about 2500rpm and let er rip. the car spun through first, all through second, then caught traction in 3rd and soon as it went into third and i have it to the floor the car just feels like it almost dies, lose power like it bogs real bad i have to let off the gas for it to move.
any ideas what it could be?
Old May 11, 2007 | 12:16 AM
Damon's Avatar
Re: Car Bogs, No Power At WOT In 3rd Gear (700r4)
Sounds like you're outrunning your fuel supply system to me. Very common when you get it really hooked up and making power screaming to redline- that's when fuel demand is greatest. If it's not keeping up it'll lay down or just about completely shut itself off until the fuel supply catches up (or you drop RPMs into the next gear) and it'll take off like a bat outta heck again.
A cheap remote-mount fuel pressure gague is the best diagnostic tool for checking this. I mount the gague where I can actually see it while driving (fuel pressure readings at idle in your driveway are basically meaningless- you need to see what it's doing at WOT, under load, all the way through a run). Personally, for simple checks like this I duck tape it to the outside of the windshield (temporarily!) and make a few runs. If you're outrunning your fuel system it will be obvious- fuel pressure will nose-dive and the motor will stuble and fall over a split second later.
Old May 11, 2007 | 07:51 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
alright ill see if i can score a fuel pressure gauge locally and try that out, i will let you know what happens.
Old May 11, 2007 | 04:10 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok bought a fuel pressure gauge and it bounces between 6 and 9, when i give it throttle it stays at 8.
is there a difference from driving it and just hitting the throttle while parked?
Old May 16, 2007 | 01:26 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
I think there is a difference. The engine should burn more fuel under load than just free revving in your driveway. Position the gauge so you can see it while you drive and try to recreate the conditions for your race and see what the fuel pressure does when you bog into 3rd.
Old May 16, 2007 | 05:28 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
some **** wipe put a pizza flyer underneath my breather in my carburetor and i didnt even notice til i put the fuel gauge in, now it doesnt bog anymore.
one more question t hough the car seems to have MORE power at 3/4 throttle then at full throttle, could my carb need to be set? and is 750 edelbrock too much for my engine or is the carb junk? maybe a holley 700 DP?
350 .30 over
flat top pistons
edelbrock rpm cam w/ 1.6 pro magnum rockers .520/.542
edelbrock rpm heads 170cc
edelbrock rpm air gap intake
march underdrive pulleys
hedman long tubes + 2.5" true duals
700r4 3000 stall
410 posi
Old May 17, 2007 | 07:56 AM
ino's Avatar
ino
Car: 87 firebird
Hey rough nice looking car
Azrael91966669
25
Jun 20, 2017 04:04 AM
AkDrifted
Aug 17, 2015 07:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
killer777
Aug 8, 2015 02:47 PM
