how to make this work??
Old Jun 1, 2007 | 08:12 PM
lewis2632's Avatar
i have a 85 firebird with a 4bbl 305 i took took the q-jet off it and bought a universal holley 600cfm dubble pumper and since it has a couple of extra vacume lines it hits in couple of places and i dont know if the cables will hook up. if any can help? i want to strip it down as much as possible with the extras i dont need
Old Jun 4, 2007 | 05:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are a lot of holes in your information, so we'll have to make some assumptions in order to answer your questions.
The stock carb (assuming this isn't a Canadian-delivered vehicle) is computer controlled, as is the distributor. Replacing one requires replacing the other, so you need a distributor with mechanical and vacuum advance built in.
If you have a stock intake manifold, you will need an adapter to go from the spreadbore intake to the squarebore carb. That should move you out of the way of the vacuum ports hitting anything. The preferred approach would be to put on an intake manifold that has the square pattern mount built into it.
The transmission requires a cable connection that mimics the stock geometry. The easiest way to do this is buy a TV correction lever (aka - "adapter") that bolts to the carb throttle arm (I used the Summit unit SUM-700202). And, you'll need a throttle cable stud, unless you don't mind the old bolt-in-the-throttle-arm-hole-with-double-nut routine.
The most important hole in your information: Why are you doing this????
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Poncho92
Aug 7, 2015 08:15 PM
