What did you do with all of your TBI wiring?
Old Jul 18, 2007 | 10:24 AM
chevyman247's Avatar
Hi Chevy Brothern,
I own a 91' Chevy K1500 350 Pick up truck and I have taken the engine out and rebuilt it and Is doing a TBI to carb conversion, and now I want to clean up the engine compartment today before I put it back in. I want to know what wires are for the TBI and ones for guages. So I can get to clipping. If someone can make a quick tutorial that would be great. or a diagram. I belive the TBI system on my truck is very much like one on a Camaro. I am usualy at fullsizechevy.com but decided to pop in over here. Here is my thread over there if you want to see pics of my new engine http://www.fullsizechevy.com/forums/...ld-w-pics.html
Old Jul 21, 2007 | 08:53 AM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Re: What did you do with all of your TBI wiring?
the only wires you need for your gauges are the water temp which is single wire on driver side cylinder head between 1&3. and oil pressure, could be next to dist. or above oil filter. the 2 wires that went to the old coil white and red can simply go straight to the new dist. reds power whites tach lead. really simple.
Old Jul 30, 2007 | 03:22 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
All the wires on the passenger side are useless now
Old Aug 6, 2007 | 01:48 PM
MickyFrye's Avatar
I dont mean to hi-jack your thread, but I had a similar question and posted it in the wrong forum. I was wondering where do I start cutting also. I mean I keep my Oil pressure sensor, temp, sensor, and oil sending unit so it will start, but how much of the computer do I disable? Where? Do I leave the relay box bolted to the intake and keep everything running through it? Sounds like I do, but I want to be sure. I leave the all the air hoses and water hoses also I know that. The distributor wires will need to remain in place too. Is it only the plugs that go to my TBI that I remove for a carb converison? Ive done the other research regarding the fuel pressure, TQConv. and throttle positioning/return, but cannot figure out where to cut off my computer.
The article on this forum helped a bunch as I did not consider the throttle return spring. However, the article did not address the computer's/relay's necessity.
-Mitch
Old Aug 6, 2007 | 07:39 PM
Car: 88 camaro
Engine: 355
The Computer runs the fuel injection and that's about it so take it right out!
Remember that you need to do something about your lockup torque converter though. Either have a toggle so you can lock it up manually or you can buy a kit that does it for you automatically I believe. I can't tell you for sure cause I ditched the lockup completely.
Old Aug 7, 2007 | 03:56 PM
MickyFrye's Avatar
Thanks for all your help guys. Ill remove it completely. Last question...What happens when I do nothing about the Torque Converter? It just turns right?
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
tero
Aug 15, 2015 02:47 PM
