what size carb?
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
what size carb?
what size carb should i put on my 91 camaro 305, it will have an agressive cam and headers, nothing extreme. what would be a good size?
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: what size carb?
a 600 would be good.. vacuum secondaries since its not gonna be wild..
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: what size carb?
holley 600 cfm 4 barrel vacuum secondaries will be perfect
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Transmission: 4L80E/4L80E
If you really want vacuum secondaries, then invest in a Quick Fuel adjustable secondary diaphragm housing. It does it the right way, tailoring the opening by adjusting the vacuum signal, not the diaphragm spring. The spring dictates how much the secondaries will open, which sizes the carb to the engine size & RPMs, but that's not a good way to prevent bog. With the QF piece, you can use a weak enough spring to fully open the secondaries, which most any engine will support, while being able to control the secondary opening rate to prevent that initial opening bog.
Having said all that, I wouldn't recommend a vacuum secondary carb. If this is your final goal with the engine and car, then get a 600 double pumper. If you have future plans and want to keep the carb you get now, then I'd say hold off buying a carb until you do whatever you're going to do in the end.
BTW, if we can assume this started off as a TBI engine (which seems safe since it's an RS), your heads are going to limit performance more than any other thing in/on the engine. The size of the carb practically becomes moot.
Billy Decker
Sep 4, 2015 03:46 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
