picking a afpr
Old Aug 4, 2007 | 01:46 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
picking a afpr
ok i need one that is return style since i will be using my tbi fuel pump. is there any other choice that i have besides the mallory 4309? is it mandatory that i use a return style regulator?
Old Aug 4, 2007 | 10:28 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: picking a afpr
yes you need a return style and i went with a holley reg it was like 60$
Old Aug 4, 2007 | 10:50 AM
Re: picking a afpr
do you have the pn for that?
Old Aug 7, 2007 | 01:16 AM
Re: picking a afpr
any luck with the pn?
Old Aug 7, 2007 | 09:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Mallory 4309 is pretty commonly used.
Looking on summitracing.com, I don't see a Holley return-style that goes down to 6 psi. But, I didn't look on Holley's site, either.
Old Aug 7, 2007 | 11:02 PM
Car: 91 RS
Engine: 350 vortec
Re: picking a afpr
http://www.jegs.com/webapp/wcs/store...61151_-1_10323
i bought from jegs as i couldnt find holleys 700DP on summit got my regulator there
Old Aug 7, 2007 | 11:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: picking a afpr
mallory 4309 > holley regulator
Old Aug 7, 2007 | 11:27 PM
five7kid's Avatar
Ah, HLY-12-803BP. $67.39 w/bracket. Not sure why it didn't come up on a regulator search, but did on a p/n search.
Old Aug 11, 2007 | 07:50 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: picking a afpr
aeromotive 13202 all the way, may not be somthing you need for a street car, but can always have it if you plan to upgrade
RedLeader289
May 28, 2019 01:47 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
