ID my power valve
Old Aug 12, 2007 | 04:46 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
ID my power valve
Got an 850DP used. Been awhile since I had to look at one. I thought the numbers on the PV were together but maybe not.
They are stamped and spaced around the PV.
L 6 5 6 or L 9 5 9
Problem is as you rotate it, the 6's could be 9's depending on which side you look at. As you rotate it, it's 9 below the L on the left and 6 above the 5 on the right side.
Do I assume it's a 6.5in vac PV
Old Aug 12, 2007 | 05:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
6.5 sounds right.
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
g.l.mos
Aug 22, 2015 12:02 AM
