Manual fuel pump on my 87 firebird gta
Old Aug 12, 2007 | 04:42 PM
pappi84's Avatar
I am thinking about pulling off my my tbi set up, and installing a carb and intake. What i wanted to know is if a manual fuel pump with work on that stock camshaft?
Old Aug 12, 2007 | 05:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
It should work. The cam should have the lobe, and the block should be machined to mount the pump.
There wasn't a TBI set-up in '87. Did you mean TPI?
Old Aug 12, 2007 | 05:42 PM
pappi84's Avatar
Re: Manual fuel pump on my 87 firebird gta
Yes i mena tpi and i was reading some did not have the lobe on the cam. and the blocks did not have the hole for the rod
Old Aug 12, 2007 | 05:44 PM
five7kid's Avatar
I can only say that the '87 LB9 engine I had was machined to mount the pump and had a pump lobe on the cam. But, the engine had been rebuilt, so the cam may have been replaced, but with roller lifter cams, that's less likely.
Old Aug 12, 2007 | 05:48 PM
pappi84's Avatar
Only reason I ask I wanted something bigger in the car and pull the motor out for my boat.
Old Aug 12, 2007 | 06:02 PM
pappi84's Avatar
guess the only way to find out is to pull the cover off and push and rod in and turn the motor over
Old Aug 12, 2007 | 08:16 PM
five7kid's Avatar
At worst you'd have to hook up an electric pump. Pretty common on boats, anyway.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
