edelbrock carb questions
i installed my edelbrock, set my timing, and tuned it in as close as i can. i hooked the dist. to the part time vacuum side but it seems to run better at the full vacuum side. the only problem is that the idle timing is now extremely advanced. is this ok. and another thing is while turning, the car "bogs" down but the rpm speeds back up after turning back straight. i have a stock mechanical fuel pump. could i still be in need of a fuel pressure regulator
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: edelbrock carb questions
Extra advance at idle is fine if the engine likes it. If you're bogging in turns, your float level might be too high or too low.
theshackle
Sep 17, 2020 08:26 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
