Q-Jet Rebuild Kit
Car: 1987 Formula
Engine: 305 LG4
Q-Jet Rebuild Kit
I have a 1987 Formula with the LG-4. It has the E4ME Rochester Quadra Jet carb. The code I found on it was 17072974. I looked it up on autozone.com and they did not list that code. They did list a bunch of other numbers. I also looked at advanced auto.com and they did not list the code either. Does anyone have a part number for the kit I need to rebuild this carb?
Thank you.
Thank you.
Re: Q-Jet Rebuild Kit
That's not the carb number. Looks like the casting # from some one of the castings.
The number you need should be stamped on the fuel bowl, running vertically up the casting, where it makes a sort of boss for a screw, just above the secondary throttle shaft on the driver's side. It will start out 1708. It'll be something like 17087201.
Car: 1987 Formula
Engine: 305 LG4
Thank you. It is a 17087306. That was a stamping number I had originally. I went to the local parts store and they had the rebuild kit I needed. Thanks for the help.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tonys91rs
Oct 10, 2015 03:31 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
