1:1 Throttle linkage?
Old Aug 12, 2007 | 12:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I just got a Quick Fuel billet throttle plate, and it came with a link for 1:1 throttle. I just stayed with the normal 40% set-up, but was curious if anyone has tried that on a mild engine. This is on the 396, by the way.
I did put the link on and played with it a little before installing the plate, it isn't a pure 1:1, as there is a few degrees of primary movement before the secondaries start moving, but I'm wondering what it would do on a street/strip set-up.
May just put it on for kicks and see what it does. . .
Old Aug 15, 2007 | 08:27 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 1:1 Throttle linkage?
have you played with it? wouldnt it be like running dual 2 barrel carbs more or less?
Old Aug 15, 2007 | 08:47 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
on the street it may cause a slight bog, having both of the plates open at a low RPM will kill what air speed is in the venturis
Old Aug 16, 2007 | 02:06 AM
five7kid's Avatar
I haven't tried it yet. Too much else going on.
The problem I see would be the lack of a secondary power valve - it would be rich under cruise. I doubt it would cause a bog, though.
I'm not sure the 1:1 would make much difference the way I'm running it now, using a 2-step rev limiter. I floor it against the limiter, then let go of the brakes and button at the 3rd amber. If I get told not to use the the 2-step (the rule wording is vague, opening it up to interpretation - nobody has complained so far), then the 1:1 might make more sense - I'd be stalling with all 4 barrels, which should make the stall-to-WOT better.
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
mfp189
Sep 27, 2015 09:25 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
