Fuel pump going from EFI to Carb
Old Aug 5, 2007 | 02:51 PM
385thumper's Avatar
Car: 1992 camaro
Engine: 385 stroker
Transmission: t-5 w/c
Re: Carb gas tank pickup
I, myself am running a carb in '92 camaro.Stock pump in place with pressure regulator.Holley 650 double pumper on a 385 stroker est. 480 horse w/ 515 ft pounds.It runs great in all applications so far.i.e. street, strip.
Old Aug 16, 2007 | 06:46 AM
redcatch32's Avatar
Car: 1988 Camaro Coupe
Engine: 420
Transmission: TH 400
Axle/Gears: 2.77
I am doing the same with a Mallory regulator. Question :did you hot wire the pump? I believe there is a 5 psi lock-out. Did you eliminate that?
Old Aug 16, 2007 | 08:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I moved these posts out of the Sticky about making a manual pick-up out of an in-tank electric pick-up.
In case you couldn't tell, I'm trying to keep the sticky "clean", only discussing making a manual pick-up out of an in-tank electric pick-up. If you are keeping the electric pump, you don't have any business posting in the sticky. Thank You.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
