carb problems(holly)
Old Aug 12, 2007 | 11:40 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
ok so im having vaporlock problems and decided i would take off the cartar 4 bbl and put the holly 4bbl on my car because i heard cartars are prone to taking heat from the engine easier.... well i got the holly on there and now when it runs it idles pretty rough and when you give it gas it slowly goes back down to idle, kinda like the linkage is sticking but its not, im not sure what either flowed but the holly did come off of a ford pickup and it worked fine on it, anyone got any ideas why it would do this?
Old Aug 12, 2007 | 11:47 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: carb problems(holly)
sounds like it's too lean, did you adjust the idle mixture screws? if not
go to holley.com and read the instruction manual for the carb you have and then report back IF it still has issues.
Old Aug 12, 2007 | 11:54 PM
mbolte's Avatar
Car: 1987 Camaro
i havn't messed with the idle screws yet, the carb was rebuilt by a shop around here in may 06 and worked fine on my truck, but they are two different motors, ill look into it, thanks
Old Aug 13, 2007 | 12:25 AM
mbolte's Avatar
Car: 1987 Camaro
also do you know where the part number is on the carb that i can use to look up which one it is?
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
