Edelbrock carb restart issue...
Old Aug 16, 2007 | 12:07 PM
Jeremysyty's Avatar
I am running an Edelbrock 750 carb (1407) on my TA. Well the car won't start immediately after I run it and leave it sit for a little while. After it sat I pumped the throttle and no gas was coming out. My thoughts are the fuel bowls drained down into the engine. Does anyone know the cause of this problem? I searched the internet and haven't found many answers. I have a carb rebuild kit and I am in the process of rebuilding the carb. I want to make sure I fix the problem and don't overlook what it is causing it. The carb is over 10 years old and sat dry for 8 of the years. I figure it desperately needs a rebuild anyways!
Old Aug 16, 2007 | 02:50 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Edelbrock carb restart issue...
The fuel in the fuel bowl evaporates. Mine does the same thing.
Old Aug 16, 2007 | 08:44 PM
Jeremysyty's Avatar
I was reading that, but I find that hard to believe. What a waste of gas!
Old Aug 16, 2007 | 10:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you pull the lid off the carb while it's warm, you can see the fuel bubbling in the bowls. That's why the stock setup uses the vapor canister and the charcoal bed in the air cleaner... to catch the vapors and burn them later.
Old Aug 17, 2007 | 06:50 AM
Jeremysyty's Avatar
Learn something new everyday, that still stinks though, luckily I don't have the car around to save on gas!
Old Aug 23, 2007 | 11:45 AM
Jeremysyty's Avatar
Well, my car is back up and running. Nothing changed except for the carb rebuild. I have not seen any fuel drain down issues. And the temperatures are more hot than I have ever ran the car before. My issue is fixed, however I never found out what was the cause!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
toronto formula
Sep 10, 2015 07:31 AM
Ranbo108
Sep 9, 2015 12:20 PM
TheExaminer
Sep 6, 2015 11:40 PM
