glass fuel filter
Old Aug 16, 2007 | 09:53 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
glass fuel filter
i want to use a glass fuel filter made by HELP! (Dorman). the auto parts store i work at sells them. they're real glass, not the plastic crap like the mr. gasket clearview ones. it looks good quality. my question is i want to mount it before the stock fuel filter but where's the best place to put it? they're safe to use, right? also, what size fuel line would be on a stock 83 firebird LG4 with a quadrajet?
https://www.dormanproducts.com/cgi-b...tegory_list=:0
^^ thats a link to the filter
thanks guys.
Old Aug 16, 2007 | 10:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: glass fuel filter
Stock fuel line is 3/8" and the return is 5/16". That thing is too small.
Old Aug 16, 2007 | 11:22 PM
they make it in 3/8''
is it a good idea idea or should i just stick with the stock one?
Old Aug 16, 2007 | 11:46 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
I have a serious aversion to those things after reading about the guy's car burning because of one... I don't recall if it was plastic or glass but anything I can see through is now avoided. I just got my Earl's filter plumbed in tonight and it's beautiful... Why are you wanting a clear one?
Old Aug 17, 2007 | 12:14 AM
a) to keep the stock filter clean and avoid having to change it as often b/c i've heard that over time the stock filter housing can strip out rather easily
b) being able to see when the filter is dirty rather than guessing
c) having 2 filters never hurt anybody
and i read that story about the fire. it was the crappy plastic mr. gasket one. apparently it was a defect in the housing that caused the fire.
Old Aug 17, 2007 | 03:16 PM
MG66Biscayne's Avatar
Car: 1984 Z28
Engine: L69
I had one of the glass filters come apart while driving on another car I owned and pour gas all over the hot engine, luckily no fire. Since then I stick with the metal filters. NAPA has decent ones.
Just my opinion...
Mike
Old Aug 17, 2007 | 04:06 PM
do you happen to know the part # off that metal napa filter? do they have the replaceable filter cartridge or do you have to replace the whole thing?
Old Aug 17, 2007 | 04:35 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
I have used a glass fuel filter for so long I can't even remember when I installed it. It sits just below the pass. side fresh air intake for the air cleaner.
Auggie
Old Aug 17, 2007 | 06:31 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I had one of these too, my car started stumbling, turned out the glass filter has loosened and leaked gas and sucked in air. I'm lucky thats all that happened. The one I had could be taken apart by unscrewing it. Not sure if thats the way they all are, but there is no way I know of to make sure it doesn't loosen. I wouldn't waste my $$$ on it, unless you're using it temporarily to check how clean your gas is.
Old Aug 17, 2007 | 08:32 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I wouldn't bother. It's just one more thing to maintain (and break) and one more fitting to leak. The stock one is $6, replacing it when recommended is cheap and reliable. I've never heard of problems with the stock fittings getting stripped unless you install the filter wrong.
Old Aug 18, 2007 | 12:06 PM
Car: 1984 Z28
Engine: L69
I agree with firebirdjosh that the stock filter is sufficient. I recently replaced the in-carb filter in my quadrajet. Just be careful with the fittings and you won't strip it. I don't have the part number for the NAPA filter, I just asked for a 3/8" metal fuel filter.
Mike
Old Aug 27, 2007 | 12:37 AM
TABANDIT's Avatar
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
My local track (Mission) doesn't allow any glass or plastic fuel filters, they have to be metal. Just something you should check out with your local track if you ever plan on going.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
