holley power valve question
Subscribe
Sep 6, 2007 | 04:08 PM
im new to holley carbs, and was wondering what does the power valve do and what are the symptoms of a blown power valve?
thanks
Reply 0
Sep 6, 2007 | 04:14 PM
Re: holley power valve question
power valve opens at a set amount of vacuum to let extra fuel in the engine.
a blown power valve would basically dump unmetered fuel into the engine at all times.
Reply 0
Sep 6, 2007 | 05:15 PM
Well, unmetered isn't exactly true. It would add an additional metered amount of fuel when not needed.
Reply 0
Sep 6, 2007 | 05:26 PM
Right, the PV orifice is sized (actually it is screw in on some applications, so you can change the PV orifice)
Reply 0
Sep 6, 2007 | 06:54 PM
Quote: Well, unmetered isn't exactly true. It would add an additional metered amount of fuel when not needed.
thanks 57, couldn't spit out the words, lol.
Reply 0
Sep 9, 2007 | 11:45 PM
I also wanted to add the wrong powervalve can add unwanted fuel and cause an over rich condition. I have seen that way to many times Big cam wrong pwr valve and it flutters open at idle
Reply 0
Sep 10, 2007 | 02:41 AM
Quote: I also wanted to add, the wrong powervalve can add unwanted fuel and cause an over rich condition. I have seen that way to many times Big cam wrong pwr valve and it flutters open at idle
just cleaned up a little spot for clarification.
Reply 0
Subscribe
