help me pick a new cam.
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
guys help me pick out a new cam. i have an xe 268 cam in there now and i do like it but im going to put on some roller rockers and springs so i figure id throw in a new camshaft. i ran a 14.02 @ 101 with this cam and setup. i want to switch over to a single plane intake as well what would you guys reccoment for that. im going to be spraying a 100 shot into it. ive looked at the weiand stealth single plane which looks good to me.
heres a little info on the setup now. i will be reusing everything but i would like to get some new ideas on the cam and intake. im open to anything just looking for idea's on the intake i dont want a really tall intake because this all has to fit under the stock hood.
*comp xe 268 cam. flat tappet hydrolic
*64 cc heads 1.94/1.6 valves comp 981 springs and comp pro mag 1.52 roller rockers.
*holley street dominator dual plane
*holley 650 double pumper milled choke tower
*accell full billet hei deistributor.
*cast flat top pistons
*cloyees double roller timing chain
*edlebrock tes 1 5/8 shorty headers with 3" y-pipe cutout and 3" flowmaster catback
*t-5 with centerforce dual friction clutch. with this cam in fifth gear i can still speed up just fine without downshifting into fourth.
*edlebrock 1/2 plate with 100 horsepower wet shot with purge.
Transmission: 4L80E/4L80E
Have the guides been cut for more valve travel?
Single plane intake is probably contraindicated. Stick with the Street Dominator, or go with an RPM Air Gap. Any single plane that doesn't add height is going to diminish performance.
Something like a Comp XE282 would bring smiles.
Spraying with cast pistons is probably okay with the small shot, but go any bigger than that, you'd better go with forged.
The T5 isn't long for this world at increased power, either.
Car: 88 IROC
Re: help me pick a new cam.
Single plane intake is probably contraindicated. Stick with the Street Dominator, or go with an RPM Air Gap. Any single plane that doesn't add height it going to diminish performance.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I find the XR282 to be fine on the street. There's enough vacuum for the brakes, about 10-12 or so inHg at idle. I've got a 383 though, but it should still be fine with a 350. Stick with a dual plane intake. The T5 is going to get shredded though.
All of the Weiand Stealth intakes are dual planes. The single planes are the X-celerator and Team G intakes. The Team G intake line is their competitor to the Edelbrock Victor Jr. intakes and available in several carb pad heights.
Which Street Dominator intake are you running exactly (part number)? Some are very very mild intakes with small ports and limited RPM potential. But if it's the good 'ol 300-36 you already have a very capable intake manifold for sub-6500 RPM performance.
I wouldn't do a single plane for only a 100shot and that mild cam- not worth the expense for the performance increase, if there is any at all. With a bigger cam and a bigger shot a single plane starts to help more.
981 springs
I would NOT put a single plane intake on it. Use a Performer RPM.
You just don't have the "infrastructure" for stepping up those things; cast pistons, small-tube headers, small carb, street valve springs.
I'd suggest working on other parts of the car to get it faster. Gears maybe; aluminum drive shaft; TRACTION; stuff like that. Remember, every .1 sec you can carve off of your 60' time, will give you between .15 and .2 at the other end of the track.
There's ALOT more to making a CAR fast, than dinking around with the motor.
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
The xr 282 cam is great for me in a 350 vortec with ported 882 heads. It all depends on the money you want to put in. I would upgrade the tranny first then worry about the engine.... just my opinion.
350 vortec, ported 882 heads, xr 282 cam, performer rpm, 650 holley vac. sec., 436 horsepower
RedLeader289
May 28, 2019 01:47 PM
